Hi every one, just bought my first truck 2000 Silverado 1500 5.3L ext z71 4x4 , car ( I mean truck, gotta get use to say truck now ) truck run and drive great, no noise or smoke, it does have 180k miles on it.
their is 2 problem I note, it say " service 4wd light on " I seen this many time on couple friend z71 truck or suv, i dont ever use 4x4 down here, but that something I might need fix in future. and low gas light on and gas gauge needle is moving slow after fill up.
Here come the maintenance, then owner say he using 20w50 on summer
and 10w40 on winter. oil cap say 5w30, what weight oil you guy think these 5.3L high miles using ? 10w40 ?
What gear oil for front and diff ? and what gear oil for transfer case. and what transmission fluid it need ? I do not have owner manual , and Im not going to use it to tow anything, but i tow it I need too.
here some pix and some question.
5.0l in the back, I still like it
it that the drain plug ? i seem cant find the fill plug.
I KNOW THE FRAM !! BIG F WORD RIGHT THEIR !
I see the transmission drain plug, should I change the filter or just drain and fill ? transmission fluid still look good, or I just do it all at 1, drain plug and take off pan and change filter . and that oil drain plug, after my friend accident strip the plug, im plan using those fomoto or something plug.
this is transfer case, those 2 plug is drain and fill right ?
thanks !
thanks !
