Originally Posted By: DSparks
I know exactly how those kinda units work....if you dont have a seperate propane burner(heater) for the water heating the units usually use exhaust heat to heat the water through some kind of heat exchanger/manifold...it is generally completely independent and after the engine ....I wouldnt be to worried about the engine oil as long as its full and engine is healthy..the engine has its own big fan on it for its own cooling.. ....you need to figure out whats up with the exhaust heat exchanger/manifold and how it controls the cycling/temperature control of the water temps....
Thank you for clarifying this DS! The only units I've ever seen are the diesel fired water heater type. Had no idea on the exhaust heat exchanger.
Having owned several flavors of Kohler, including one Command 20 V-twin and one Courage 20 V-twin, they throw off some heat, but I had no idea it would be enough for any volume of water w/out puking cooled exhaust and condensate gunk out the exhaust end.
