Originally Posted By: A_Harman
Yes. Diesel engines rarely get above 1250F on turbine inlet temperature. If they get to 1400F, the turbo becomes susceptible to bearing problems. Gasoline engines get to 1700F turbine inlet very easily, and can easily top 1800F if the mixture isn't tuned excessiveley rich.
Thanks, I didn't know they ran that hot. I guess diesel combustion temperatures must be higher for a given EGT due to the extra compression.
I'm pretty sure my buddy goes over 1400F with his 5.9 Cummins' on a regular basis, but he has also taken out a factory turbo on one - bearings simply got noisy at around 100k miles - and even once melted the pistons to the cylinder walls on another when he got carried away with the programmer on a stock turbo without his gauges hooked up.
This is an interesting thread. I apologize for derailing it a bit!
