I was on my Marauder forum reading some posts.
The Mercury Marauder has an external transmission cooler mounted between the A/C Condenser and the radiator. It has a 180 degree thermostatic bypass on the external cooler. I guess if temps are below 180 degrees the fluid bypasses the cooler.
This car also has the trans cooler in the radiator too.
Some guy decided to put another trans cooler on this car, he put a tube and fin type cooler in front of the A/C Condenser, I am thinking this is overkill and there could be a pressure losss in the transmission.
I always thought that tube and fin type coolers were old school, the stacked plate design is 30% more efficient, with less of a drop in pressure.
This sounds like a waste of money in my opinion.
