I'm wondering.. and I kinda know the answer, but I need to clarify my doubt.
my 92 Taurus is going to get an external transmission cooler.
the correct way would be to remove the outbound cooler line from the radiator cooler and run it to the external then back to the line.
getting to the transmission lines isn't an easy task on this Taurus, and my time isn't what it used to be.
I'd like to just cut both transmission lines where there's a section with rubber and run the cooler off those lines. They're easy to get to and would eliminate the radiator cooler all together.
I would be losing maybe a half quart of ATF given the transmission lines wrap up and around the front of the radiator (finless).
I'm willing to sacrifice this for a better cooling ability.
Would this be a good idea to bypass the radiator cooler as well? I would think Yes.. however.. the ATF might get to cool in the winter time? Although California winters are nothing to be concerned about where I'm at.. it's always hot to me..
Also.. anyone know what size the transmission line is? I'm thinking 5/16", and my cooler has 3/8". So I'd have to make an adapter. My factory manual doesn't state exactly what it would be either.
