Originally Posted By: Batmanj30
Originally Posted By: Pesca
You did not tell us what is the change interval and what is your annual mileage (also we could calculate it).
Like Weemay wrote, any oil that meets SM 5w-20 is enough in your car, even conventional oil.
Depending of your OCI and your annual mileage, you can shorten the list of oils that may meet your requirements.
i normally run 7500-10k miles of 5w30 (82k miles currently), a little over depending on the work schedule and timing issues. my annual? ive lost track, probably, 30k+, and thats being generous. considering how much driving i do highway for work.
Ok, then I will continue on synthetic, and since you drive a lot, and probably don't have much time changing oil often, you could try the extended drain version of the synthetic oil.
First oil that comes to mind is Mobil 1 Extended Performance 5w20 which seems very well regarded here and see if you can push it to 15k miles OCI.
From what I understand you can buy it at walmart for about the same price than regular Mobil 1 when it is on rollback.
Other choices are PU, Castrol edge, and other main brands.
