Originally Posted By: Hokiefyd
Originally Posted By: Zero
My apologies for omitting this; it's a 2003
Thanks; a 2003 Camry would have either the 2AZ-FE engine (2.4L DOHC I-4) or the 1MZ-FE engine (3.0L DOHC V-6). The 2AZ-FE, the I-4, indeed has a timing chain with no recommended maintenance interval. That is, the chain is designed to be good for the life of the engine. Some timing chain systems are better designed than others; I don't know of any widespread reliability issues with the timing chain systems on the AZ series engines. The 1MZ-FE, the V-6, does use a timing belt that would have to be replaced on a regular interavl.
It's the 2AZ-FE engine.
Again, the only issue I could find was with the intake.
