Just put a thousand miles on a 2014 Malibu LS with the new 2.5 Ecotec and 6 speed auto driving around New England on vacation. After noticing a strange "jolt" at intersections I realized the car has the new Auto-Stop system.
The system works pretty well but seems to often not "auto-stop". If you come to a stop too smoothly, the system thinks you might be in stop-and-go traffic and keeps the car running. If you brake abruptly, the system immediately stops the motor till you remove your foot from the brake. The starts were pretty quick and you can hear the regular starter noise when the care re-starts. Reading up on the system, it has a second battery to prevent dimming of the lights during auto-start and it has an electric transmission fluid pump to keep the trans ready to go in an instant. Starter is supposed to be strengthened to handle the repeated cycles but I guess time will tell how long it will really last. Overall, I could live with the system but it is noticeable when you want to start in a hurry. Doesn't really delay anything, but you feel more of a jolt as the motor re-starts. You learn to remove your foot from the brake and wait an instant for the start to happen before you accelerate which makes the process smoother.
As for the Malibu itself, it drives nicely and the motor is VERY smooth for a 4-cyl but still has that buzzy sound as most 4-bangers do. Highway cruise is very quite (MUCH quieter than my 2013 Accord) and the suspension is good. Lousy visibility out the back though when backing up. The Ecotec, although rated as a strong motor feels kinda weak, more due to the transmission I think. You have to really rev it to feel the power. "Drive" grabs the upper gears at very low speeds so any throttle increase takes two down-shifts to get the car to accelerate which is kind of jerky. You can go to manual mode but the toggle switch on top of the shifter isn't very intuitive to change gears with.
Just thought I'd give my impressions! Oh, and the oil life monitor was down to 15% at 6000 miles which is when I turned the car back into Hertz - I would think on the original fill.
