- Joined
- Aug 4, 2021
- Messages
- 138
Cannot figure out misfire from a 1999 gmc sierra 1500 4.3. Truck starts and idles great cold start but aftet 5 minute warm up and going on a cruise it studders. I first got cylinder 5 code and then cylinder 3 then multiple cylinder. The maf, iac, tps, fuel pump, fuel filter, pressure regulator, spark plugs, wires, cap and rotor and chip have all been replaced within a year. With good quality ac Delco parts for the most part. Also did a leak down test on fuel system a month ago (how i found regulator leaking) and after passed smog and has never ran better. I did find a hole on a vacuum line from the smog pump to the plenum and replaced it and would appear that solved it and drove quite a ways before it started misfiring again.i cannot find anymore air leaks any ideas? Also could i have messed up spark plugs from test driving on misfire?
