1999 Ducati ST4 engine oil?
Finland
Hello.
So I bought recently this 1999 Ducati ST4 as a project. Project means that it will need some serious engine work as at least main bearings are shot.
I'm trying to figure out the engine oil ie. what to use in the future.
Engine is a share sump but with dry clutch.
Factory recommendation is 20W50 and Ducati recommend Shell Advance Ultra but that is not so easy to get these days here.
Easiest way would be to get Motul 5100 or 7100, both 15W50 or 20W50 and be done with it. But then there is also Castrol Power 1 20W50 which is very cheap.
Any idea how this Castrol does in normal circumstances? I do not recall ever having used Castrol oils in bikes and/or cars.
Also, how would Valvoline VR1 20W50 mineral oil "survive" in a shared sump engine? That is what I use in my Harleys and BMW.
I'm using Castrol Power 1, 10W-40 full synthetic in my XSR900 and it seems fine. Shifting is good and the engine doesn't use any of it. No reason to not give the 20W-50 a try in the Ducati.
The recommended engine oil for a 1999 Ducati ST4 requires a viscosity of 15W-50 or 20W-50 synthetic oil, an oil capacity of about 3.4 to 3.5 liters (approx. 3.6 to 3.7 quarts) with a filter change, and an API classification of CC, CD, or CE (or higher-grade motorcycle specific 4T oil). Alternative Grades: SAE 10W-40 or 10w-30 (for lower ambient temperature ranges)
I’m running Castrol Power 1 20W-50 in my 1989 Harley Electra Glide Classic in both the engine and primary. It seems fine to me.
Thanks guys. (y)
Castrol looks interesting. Need to see first what the actual level of the engine damage is before deciding.
Thanks for sharing. I have not seen a recommendation chart that comprehensive. Never would think Honda would recommend 10 wt for up to freezing, lol.
