1997 Honda Civic Drive Belts Replacement Cost
Olathe, KS
It's a little more of job than I want to deal with. Any ideas on what I would be looking at labor wise for a shop to do this for me?
Usually you have them replaced at the same time as the timing belt. The timing belt is also much easier to replace than on most other cars.
On one of the belts you have to remove an engine mount. And then you need to get them tensioned correctly since there isn't an automatic tensioner. It's more dinking around verses doing a serpentine belt.
Look into Bando drive belts, as they are an OEM supplier. You can get them on Rock Auto. If your 97 model is remotely close to the 98-02 model, then those belts are easy to replace. Just don't put too much tension; this can't be emphasized enough.
