1996 Geo Metro CEL- P0335
Baton Rouge, LA
Ok, I've posted on this before and I will update. I hope someone can chime in who has experience with Geo, Chevy, Suzuki.
First off, my car cranks fine, runs fine, still gets me 40 mpg everyday all day. Everything "seems" ok.
I've got a P0335 code that won't go away on my Geo. So far to correct this problem I have:
-Installed a new crank sensor
-Removed the oil pan and replaced the gasket using RTV sealant
-Removed a piece of a paper clip I found inside the crank sensor hole.
Today I removed the old gasket and used RTV to re-seal. I was told that an aftermarket thick gasket on these oil pans will cause an erratic signal to the crank sensor causing it to trigger the code. Well, while doing so I noticed when I was under the oil pan that something looked funny inside the crank sensor hole. I thought it was part of a wire or something, but no, a piece of a paper clip! So I though surely this is my problem. It was stuck to the magnetic tip of the crank sensor.
I went ahead and used the RTV, replaced the oil, cleared the code, removed the negative battery cable for an hour, replaced the cable after an hour, restarted the car, 5 seconds later, BAM! CEL back on. P0335- crank position sensor circuit malfunction.
Any ideas?
i had this happen many times at the shop with non oem sensors i had to return/exchange a maf twice to auto zone before i got a good one
Try another one you should be able to return that one and get another within a certain amount of time at least in NJ you can...
You could also test the one you have but its easier to replace it and hope you get a good one
The way that code reads, it seems like its trying to say the circuit is bad. IE, either the sensor itdself is bad or there is a wiring problem causing an intermittent or erratic signal. Thats what I would do now, is start checking out the wiring. Also, some vehicles have two crank sensors.
