1994 Civic LX 1.6L Automatic Transmission Fluid
CA
Need to drain the Automatic Transmission Fluid (ATF) to a 1994 Civic LX 1.6L (Automatic).
Do we have to use Honda Automatic Transmission Fluid (ATF)?
Are there any other approved ATF's that can be used?
Any advice is greatly appreciated
Maxlife, Castrol Import, Honda DW-1, Idemitsu. I believe they are all synthetic.
Takes 3 quarts... Easy $$.
All good.
I would do 2 spill and fills; 1 now and another in a week.
All good.
+1
Castrol Import is not synthetic though. Not sure about DW-1 or Idemitsu.
Valvole Import Multi-Vehicle. I think it's thicker than Maxlife which is good for older vehicles. But really both should be fine.
Originally Posted By: JC1
I have a 97 Civic, It's been using maxlife for the past 10+ years. I'm the original owner.
How smooth does the transmission shift?
Never noticed any hard shifting
Use Castrol Full Synthetic ATF. It is on sale at AAP for $5/qt
Originally Posted By: Warstud
I believe Hondas are picky when it comes to fluid. I'd use OEM fluids only.
No, they're not. They love Valvoline MaxLife, Castrol, etc just fine.
I have a '99 Civic with 248k on my original transmission. I've always used Honda ATF. Would others work? Probably, but since Honda ATF has gotten me this far, I don't see a reason to switch now.
