I have a ford escort with the bullet proof 1.9 litre. It currently has 193,867.3 miles on it. I am the second ower of this vehicle. It only had 76,500 miles on the clock when I bought it. To say the least it has benn a wonderful car. Great milage no oil leaks or usage. The question is the last hundred thousand miles it been a beat around car. My grandama to my ex to many of my friends have been the primary drives of this vehicle. The only reason I still have it is for that reason. I am the nice guy that has the extra vehicle that is less this beaty but runs great. So if someone needed a vehicle that I know it a copy of the lisence and a call to their insurence to check it out and it gas and go. The problem with that is doing normal maintence on time or milage. The last hundred thousand has been oil changes of nothing shorter than 13,000 miles but not past 17,500 miles. still with 193,000 miles on it never been opened up it is lucky to use a quart at or past 10,000 miles. My problem is my boyfriend is driving it now and just told me the milage on it today. 193,000 miles. I check the stick and my recorded and the manual in the glove box and all three say the last oil servive was done at 167,000 miles. When that was changed Pennzoil LL 15w40 was used with a mc fl-400 filter. at that mile of oil drain it has only used 1.75 quarts of oil. I plan on dropping it wednesday. I was wondering if any of you guys would be interested in seeing an uoa on a 26,000 mile oil drain with a 1.9 litre ford ohc with 4.5 quarts of Pennzoil Long Life 15w40 and a mc oil filter with just 1.75 quarts of mc 5W-20 as make-up oil?
Rabbit
Rabbit
