TechnoLoGs
Thread starter
I'd pay a shop $75 for an hour to get the timing right and get you to pass emissions, before trading this thing on a sunfire that you'll have to pay at least $75 in ownership transfer costs.
That is the plan. Particularly since I think Mr. Sunfire caught a beam of light out of my inbox? But yes, the plan is to let a reputable shop do the timing.
The car sounds better and runs "ok" with 'whatever I did' however I can feel it it is low on trans fluid, wherever that transmission fluid leak is. Will put in actual fluid before stop-leak.
The Blazer is showing signs of promise, running smoother, still with a misfire but it is probably: 1. Loose wires 2. Old bad cap/rotor 3. Maybe a bum coil or wires and ? and so many hands have touched it that maybe 6 new plugs, wires, dist. cap/rotor, COIL, and timing are in order.. maybe the miss will go away.. Because I see the logic: Clean up timing, I already see improvement. THEN evaluate codes/02 sensor, THEN go to emissions. Yes?
It also seems to shut off smoother with the new timing and I still am putting many fuel cleaners through tank.. something tells me much cleaning is/was needed there.
