Originally Posted By: Papa Bear
What did Interstate say when you contacted them about this problem ??....
For the first one that leaked everywhere but worked fine, I just went to an Interstate dealer and after contacting Interstate on my behalf it was eventually replaced (100%, I believe). They wanted to see it leak on the bench. Since it was replaced for free, maybe it did.
I haven't contacted anyone yet about this second one until I had ruled out the charging system or parasitic loss (which I now have).
I will probably contact Interstate about both the overfilling and the weak behaviour. I think I'm entitled to ~30% under the 85 month pro-rata warranty. There's a couple of catches I forsee, however:
1/ I bet that just like tires the warranty replacement program is against MSRP and not the street price for these batteries. 30% off of MSRP will probably be the same cost or more than the street price of the same battery, netting me nothing from the warranty. I had the same thing happen to me with tires once.
2/ If it still comes overfilled and with a tendency to leak, I don't know that I want another remote vented Interstate even if I get 30% off. I know JCI gets top marks and tons of people love their Interstates but I've had two remote vented ones in a row that were pukers.
I'll be contacting Interstate and looking for a local East Penn/Deka dealer next week. I'm going to see where I can get Deka's AGM line and/or "OE exact fit" line too, although they both may be too pricey to bother with compared to flooded. I have to say that I have a Deka POW-R-SURGE 70Ah gel cell that's probably 20 years old. I floated it with a big 12VDC power supply for a few years to power a bunch of amateur radio and communications stuff a long time ago, now I keep it handy to use with inverters during power failures. It still holds a great charge and has lots of power.
I think my latest measurements of 75% or less specific gravity immediately after bulk charging probably means that the battery's life is simply used up and it doesn't have the reserve capacity in this weather to maintain an adequately high charge between our longer road trips. If it were warmer I may not have even noticed any problems yet.
I will say that I'm very happy that this battery hasn't failed in the 10.4VDC stranding mode, which every battery the family has had prior to now has. I remember in the mid 90s the factory battery on my Integra failed in that way and, being stranded, I bought the "best" Canadian Tire Motomaster Eliminator with their best warranty. I needed a new battery every 18-24 months or so under that warranty plan. They were probably Exides, from what I've read. Sure the warranty covered most of the replacement cost (never 100%) but the stranding simply wasn't worth it. Luckily being a manual I perfected the art of bump starting alone in a parking lot - open the door, turn on the key to prime the fuel injection (still had 10.4V), put it in reverse, clutch with right foot, push on ground with left, pop clutch, push clutch, yank parking brake, engine running, drive to Canadian Tire and get a new battery. Luckily that thing would start with a 2' push. I don't want to try it with my 5 series unless absolutely necessary.
