Originally Posted By: TechnoLoGs
Results: FAIL!
Secondary Emissions - TEST:
Gas Cap = PASS
Tampering = PASS
Visible smoke = PASS
Liquid Leak = PASS
Indicator Light = N/A
Misc. Emissions = PASS
Primary Emission Test performed - TSI - FAIL
Mode: IDLE - FAIL
GAS READING STANDARD
HC ppm 783 220
CO% 7.93 1.20%
CO2% 9.5%
O2% 0.4
Mode: HIGH IDLE - FAIL
HC ppm 829 220
CO% 8.05 1.20
co2% 9.1
O2% 1.2
Here's his old results.
Anyone have his VIN so we can get his passing results?
I'm not sure he's going to cooperate with us so we know how much of an improvement there was.
BC.
Going to get my VIN now...
Inspection Type: RETEST
Workstation ID: CL270304 Model: BLAZER Sticker#: 1517108
Odometer: 184443
Fuel Type: GASO
GVWR: 5100
111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
FINAL RESULT: PASS Overall Safety Results: N/A Overall Emissions Result: PASS Credentials: PASS
This test was performed in conformance with section 207(b) of the Federal Clean Air Act and the Inspection Sticker Date is
09/30/2015.
Primary Emission Test Performed: TSI - PASS Secondary Emissions Test(s) Performed:
Mode: IDLE - PASS TEST RESULT:
GAS READING STANDARD Gas Cap PREVIOUSLY PASS
HC ppm 131 220 Tampering PREVIOUSLY PASS
CO% 0.86 1.20 Visible Smoke PASS
CO2% 14.1 Liquid Leak PREVIOUSLY PASS
O2% 0.9 Indicator Light N/A
Misc. Emissions PASS
Mode: HIGH IDLE - PASS
HC ppm 140 220
CO% 0.91 1.20
CO2% 14.1
O2% 0.8
EXPLANATION:
TSB: 00-07-30-022D 00-07-30-022D: NO REVERSE, SECOND GEAR OR FOURTH GEAR (REPLACE REACTION SUN
SHELL WITH MORE ROBUST HEAT TREATED PARTS) - (JUN 10, 2008)
TSB: 08-07-30-027 08-07-30-027: NO MOVEMENT WHEN TRANSMISSION IS SHIFTED TO DRIVE OR THIRD -
NORMAL OPERATION WHEN SHIFTED TO SECOND, FIRST OR REVERSE (REPLACE FORWARD SPRAG
ASSEMBLY) - (JUN 4, 2008)
TSB: 01-08-42-001F 01-08-42-001F: EXTERIOR LAMP CONDENSATION AND REPLACEMENT GUIDELINES - (MAY 2,
2008)
