What type fluid for 1992 Ranger's brakes? I have some DOT 3 and some synthetic DOT 4 on hand. What should I use? Have no idea what is in there already. Thanks!!!
All brake fluid is synthetic, there is no such thing as "conventional brake fluid" It is all manufactured to variousa military specs. Which is identified by the dot numbers.
You can mix and match DOT3 and DOT4. DOT4 is basically the same as DOT3 but has borate esters added to raise the boiling point somewhat. It's best to use fluid from a sealed bottle only as brake fluid absorbs moisture from the air.
