1970s Ford V8 oil recommendation please ?
uk
Hi all,
Looking for oil recommendation ,I'm in Ireland so don't have all the options available in US
Temperature 20F - 80F approx ,not too hot or cold !
My local shop has Valvoline durablend 10w 40 synthetic/mineral blend ;
http://www.valvolineeurope.com/english/products/engine_oils/durablend/cid(619)
opinion on viscosity & zddp level for the cars below ?
1971 Ford Torino 351 cleveland completely rebuilt with roller tappets I believe
1972 Ford Mustang 351 cleveland 50k miles never been opened
1960 Chevrolet 348 90k miles stock
currently using Miller classic performance mineral oil 20/50 which has high zddp level ,I'm
thinking it may be a bit on the heavy side for good startup lubrication.
Thanks in advance for advice
Back then the old man used straight 30w. I guess those older engines weren't as fussy.
Then around 1974 he bought a brand new, baby blue gran Torino station wagon with a 3 speed on the column, vinyl floor covering, vinyl seats, seat belts, am fm radio and heat. My uncle was a Ford Rep for the big truck division and he switched us to 10w30. Saying these "new" engines require a range for winter and summer.
We switched everything over to 10-30 55 gallon drum from the texaco oil man. never had any problems and we ran all those engines until they needed rebuilt usually around 100K. we always had 8 to 10 engines to service we had a farm, we did all our own work. I remember in the 60's Sears used to sell short blocks then we would buy them from or local NAPA store. Those were the days I was a kid and we were there so much the NAPA guy knew me by name.
That Valvoline Durablend should work fine in everything you have. If you can get Mobil 1, either 15W-50 or 0W-40 would be great. Even the Mobil 1 10W-40 High Mileage would suffice.
Sweet Torino wagon!
Yeah I would stick with a 10W30. They just dont seem to mind much what's in them. Compared to modern clearances and tolerances, these "big dumb animals" just run on whatever.
I also have a 50 Gallon drum of Pure branded 30W from the 60s that I have periodically run in cars from that vintage and they just don't care.
Originally Posted By: jayg
Sweet Torino wagon!
Your using oil that has been sitting almost 50 yrs ?
Sweet Torino wagon!
Yeah in a cool dry place. Its all liquid amber with no seperation and I've never had a wear related issue in the 4 years I've been doing it in my old cars and lawn mowers. I use modern oil in my modern cars.
Sweet Torino wagon!
Interesting ,Thanks for verifying that
First off I would like to say, Nice stable of cars. Second, I think a good 10w30 should work good. To be on the safe side. Try to run something with alittle more ZDDP in it.
GHOSTFLAME...Nice wagon. I remember them there cars. My dad worked at a Ford dealership as a mechanic and would bring home cars like that...NICE
i had a 72 ford torino. bought it when it was 2 years old. 351 windsor engine. used 10-40 castrol oil back then 4 quart fill after change, every 3000 miles. 10/40 was factory spec back then.
That's a 1972, beginning '73 they got the Fed mandated "snowplow" bumpers...
I use QS Defy 10W-40 in both my '69 428CJ Fairlane and my '72 Mercury Comet...
As others have noted; a Heavy Duty Engine Oil (HDEO) in 15w40 (such as Rotella or Delo) or Quaker State Defy in 10W-40 would serve those engines well. I had a 1969 Mach I with a 4V Boss 1970 351C engine in it and a 1972 Gran Torino Sport with a 2V 351C and I used 10W-40 in both of them and they ran to about 150K before needing rebuilds (typical for carburetor engines of that era).
I realize that I mentioned Mobil 1 0w-40 and then didn't give a reason why.
Any engine, old or new, can benefit from the advantages of a modern lubricant formulation like this one with its relatively high VI, excellent low-temp performance and strong anti-wear package. Simply because the engine is old doesn't mean it needs to run an "old school" lubricant. I've used Mobil 1 0w-40 extensively in older Ford Windsor engines and wouldn't hesitate to use it in a Cleveland either.
1960's and 1970's Ford V-8's were tough, and not fussy engines.
Dad had a 1967 Mustang 289 he drove HARD from 1970 to 1978. It probably got basic 10w30 or 10W-40 oil changes of the time, and AFAIK it never had engine problems right to about 150k miles.
