Originally Posted By: clinebarger
Originally Posted By: sasilverbullet
Yes, me again with another issue with my newly overhauled 460. I didn't realize that I needed to be an automotive engineer to get all this stuff to work! I don't know that I'd do this over if I knew about all the hassles.
Car starts and runs great except when hot and sits for 15 min or so. Starting it takes quite a few cranks and when it fires, it seems to be running on two cylinders. I have to baby the gas pedal and get the rpm up to about 2500 for about 5 secs, then it runs fine.
I used a laser temp gauge on the Edelbrock 2166 manifold, right below the carb is about 204, and the Edelbrock 1406 carb right above the phenolic spacer is about 185 degrees.
The engine shop says I need to trash the Edelbrock and put a Holley on there.
What do you guys think?
The 1406 is a 600cfm? That wouldn't feed a smog era 460 truck motor with 4 degrees of retarded valve timing, The '70 Lincoln 460 is pretty hot. The 1406 is calibrated to a mild 350 Chevy for economy.
Jegs has a Chevrolet Performance 4160 Holley 770cfm, Electric choke with quick change vacuum secondaries for $431.99....That is CHEAP for a 4160.
ALL Edelbrock AFB carbs are designed to run NO MORE than 5.5 psi of fuel pressure, I run them around 5psi, Adjust float level...Which is always to high, & Use an isolated gasket or a small phenolic spacer....Do all this & the hard hot start will go away.
I disagree with the assertion that a 600 won't feed a 460. It's relative I say. A 600 is usually within the range that most carb selection tools will recommend. Heck, Holley recommends a 390ish CFM for up a 360 in engine. If the OP isn't goin racin, then a 600 will give nice crisp throttle response and return decent economy. As for fuel, the OP had his engine dyno'ed prior to installing it, so I would HOPE the place the dyno'ed it checked/set fuel curves. I know the OP said they set timing...
I do very much agree with you that the float level needs to be verified. That was my first thought as I have run into it many times with Holley carbs. Different carb, same symptom, and likely the same cause.
OP- try cracking the throttle open when you attempt another hot start. I bet she comes to life a bit easier.
