I "might" consider a 15w-40 in this engine. But only if it were worn to the point of needing it, not because of any perceived need for ZDDP. The 40 Series engines in the Special were relatively low-compression (I think the OP's is 7.6), and didn't present the valve train loads of more modern engines.
Just about ANY current PCMO will provide far superior lubrication than any API-SB 1952 era oil ever could, and I don't care what's in the latter.
A seven quart crankcase is good stuff on the 263 eight. But I would still lean to an HDEO because of the carb. And I'd steer clear of any synthetics.
FWIW, my father replaced the '52 Special with a '64 LeSabre V6. That one was still tooling along with its third owner almost to 1980, when we lost track of the owner.
