11 Tundra 5.7 4wd ATF choices.
New Jersey
I'm planning on doing a few drain and fills on the Tundra.
Just hit 100k. Very little towing, Daily driver.
My thoughts on ATFs
1) Toyota OEM WS
2) Idemitsu Type TLS-LV
3) Valvoline MaxLife
Any preferences on the ATF choices above?
Thanks in advance.
Merry Christmas!
God Bless America
Multi-vehicle fluids are not okay but using Dexron VI is? Huh?
Multi-vehicle doesn't mean multi-make. Multi-make is a compromise fluid formula made to suit numerous specs. Dexron VI has a specific formula made for GM and can be used in other vehicles calling for similar specs. Whenever I've asked here about Toyota transmission fluids, I've been told Dexron VI is the same stuff.
The only published similarity between Dexron VI and WS is the viscosity. Outside of viscosity, the formulation differences (wear pkg, friction modifiers, etc.) are unknown.
not on your list, but amsoil signature series fuel efficient (lower vis) ATF has been stellar in both WS application I've used it in, 2006 Tundra 5 spd and 2014 lexus GS.
