100 year old man outlook on oil.
Overkill your right on.Just a comment here,People overlook the power of positive thinking.I have traveled through canada and united states taking seminars and course,s on positive thinking and self motivation.Every goal that i have set i have achieved,and some were big ticket items.It is your mindset some people think it is hogwash but it,s not.I,m living proof of it.
"think positive and things will come your way"
I have 179,150 miles on my 92 Cavalier RS that is my daily driver and I don't have any engine related problems and I use PYB 5W-30. It will still almost peg the oil pressure gauge at 80 psi when cold and runs about 35 psi hot in gear. I'm sure the engine will last a long time.
Wayne
[/quote]
When the manufacturer calls for 7500mi OCI's and you're changing it at 3000, that's wasteful. Since oil could become noticeably "dirty" at even 2000mi,
Quote:
But your entire comment is ludicrous and ignorant.
You assume quite a bit. First, you assume that someone would equate dark with dirty. The paper blot test as well as just feeling the oil can differentiate between dark and dirty. Second, I do read, quite a bit. There was not much to read in your post except to say that changing oil early is a recognized way towards engine longevity. You further state that that is a wasteful practice ifnot done at an interval you find correct. How do you know how many miles this man runs his oil before he deems it dirty? How do you know what type of oil he uses, you dont. As I said. Many Assumptions.
Originally Posted By: coolbird101
If only this 100 year old gentleman had the wisdom you have, lol . Can you explain how oil gets better with time, this is news to me. So your saying oil with 5,000 miles is in better condition than oil with 1,000 miles on it. Maybe you have misinterpeted a metal rise after an oil change as indicating the old oil was better than the new oil, this conclusion could easily be reached if you dont take wear averages over the life of the oil into consideration. Im not saying 3000 miles is not overkill because in most cases it is, but your painting a pretty broad stroke here. I have been doing extended oci for the last 25 years but im certainly not under the illusion that my oil is getting better with age like some fine wine.
Originally Posted By: RiceCake
Originally Posted By: johnachak
So when does frequent pm stop becoming a waste of resources? At the split second before the engine explodes from too long an oci? Apparently, anytime before that would be wasting resources.
When the manufacturer calls for 7500mi OCI's and you're changing it at 3000, that's wasteful. Since oil could become noticeably "dirty" at even 2000mi, which is where I could see some people would change it based on that assumption that "dark is dirty", is very wasteful. If you're using good oil that is still healthy to 10000 or 12500mi, you're starting to use oil more effectively (the manufacturer has a margin of caution, so with UOA's most people, here at least, know how far they can safely push their oil). Changing it according to the manufacturer is a solid baseline, if you can change it less frequently then that and have an oil that is well within its capability to handle the extended OCI, its being efficient and wise.
But your entire comment is ludicrous and ignorant. Oil gets better, testing shows that, proper preventative maintenance means you can go longer without it. Somehow you've equated my comment on changing your oil at proper intervals being less wasteful then overly frequent or recreational oil changes or feel-good assumptions that "dirty is bad and it always has to look clean to be working", to me somehow saying everyone should absolutely neglect engine maintenance and run nowhere on the side of caution and stress every single OCI to 20000mi or more; I never did, try reading next time.
From what I understand about oil is that when new it doesn't protect as well as when it gets some miles on it. In effect the oil needs to break in to achieve its full effect.
Then there is the article written on the home page that explains the anti-wear layers being applied and removed by new oil in the sump.
Really great info. Goes against what I would assume as fact but I'm here to learn.
Clevy, thank you for the info and reference, I will look into this some more, any idea when oil is at its peak performance? I never gave it much thought until now, I figured fresh oil or maybe 1 heat cycle it would be at its very best, I may need to refigure..
NP.
Dnewton is an invaluable resource when it comes to info on this site. He wrote the article I was referring to.
Reading it is free and its contained info is surprising. It goes against what I would normally think but the info comes from SAE papers. If you can't trust those then I don't know what to trust
The OP is creating his own signature after each post. Not that it's good or bad, I just think it's interesting.
And some 100 year old peeps are very wise, some have lost their minds. Not saying one way or another. It's just interesting.
