http://www.bobistheoilguy.com/motor-oil-102/ if you all go to bobistheoilguy at the homepage, you will find out more info. If your looking to find out where all those oil electrons and such are going, doing, staying, its there, imho. check it out.
They'd be pretty close until hot, then the 0-30 would be thicker.
This is for normal ambient temps.
Like mentioned, when below 0F, the 0-30 should have an advantage.
