Seth
Quote:
Seth, you probably know this, but don't be fooled by the "0" in 0w30 vs the "5" in 5w20 - the 5w20 is going to be thinner at temps across the board (low and high).
Here's a quote from motor oil bible
"Results from the Cold Crank Simulator (CCS) and Mini-Rotary Viscometer (MRV) tests are used to
determine the oil's "W" grade. The better the engine "startability" of the oil at low temperature, the lower
the W classification. Each W grade must meet certain "startability" requirements at a specified
temperature.
For instance, a 0W grade oil must have a maximum CCS centipoise (cP) value of 3250 @ -30 degrees
C as well as a maximum MRV cP of 60,000 @ -40 degrees C. A 5W grade oil must have a maximum
CCS cP value of 3500 @ -25 degree C and a maximum MRV cP of 60,000 @ -30 degrees C. The
lower the cP value for both specifications, the better.
Notice that the 0W grade oil is tested at a lower temperature on both tests AND must still have a lower
CCS cP value than a 5W oil which is tested at a higher temperature. As a result, a 0w30 will allow your
vehicle to start easier on a cold morning than a 5w30 will. Likewise, a 5w30 oil will pump easier in cold
temperatures than a 10w30 oil will."
