Would I be better to run 0w30 or 5w30 in a 2016 crv with consumption issues? The only 0w30 available near me in 5qt jugs is mobil1, where as 5w30 is plentiful in every brand…not sure what to do…0w20 just disappears in this thing
There’s no physical leak so I assume it’s burning it somehowHow is the current oil disappearing? Being burned? Leaking?
How many miles on the engine?
Any brand better in the 5w30 department? Still want to use full synthetic. I’m thinking either QS, Pennzoil or CastrolI generally prefer 5w/10w30's as they often contain less VII's and are generally less volatile. This does not necessarily mean you'll see less oil consumption, but its worth a shot. I'd even go with a 10w30 in your case.
Honda 2.4's are known to consume oil. Honda went through a period where their low tension rings were causing oil consumption issues.
Try it has see if it has an impact on the consumption, if it doesn't, well, you at least checked. M1 0w-30 was one of the oils that didn't consume in our Expedition.Would I be better to run 0w30 or 5w30 in a 2016 crv with consumption issues? The only 0w30 available near me in 5qt jugs is mobil1, where as 5w30 is plentiful in every brand…not sure what to do…0w20 just disappears in this thing
I can't make any assumptions or speculations about what's wrong with your engine, so I'll assume that it just isn't clean, especially around the piston rings.…0w20 just disappears in this thing
I’ll try just running the 5w30 first, I’m guessing it’s the low friction piston rings allowing oil by and burning itI can't make any assumptions or speculations about what's wrong with your engine, so I'll assume that it just isn't clean, especially around the piston rings.
Buy a quart of this: https://www.advlubrication.com/products/engine-cleaner?variant=40836981883073
And get a jug of Mobil 1 5W-30. The engine cleaner above is a fully formulated synthetic oil. Add it to four quarts or less of Mobil 1. I believe yours takes 4.6 quarts.
Run it for 2000 miles. Then dump it. Change the oil filter as well, which is the most important part. Always change your filter when you change your oil.
Then run Mobil 1 EP 0W-20. If you still have oil consumption issues, circle back and provide more details.
Keep in mind, that motor oil alone can't fix mechanical problems or design flaws.
Your oil control rings might be plugged up with gunk and carbon, and that's the worse assumption on my part. Running 5W-30 by itself won't change much. If you want to go that route, I recommend running an OCI of Mobil 1 FS 0W-40. It's basically a 5W-30 but it contains some mild cleaning power in the form of Esters. Red Line 5W-30 would be another option, but that one is expensive.I’ll try just running the 5w30 first, I’m guessing it’s the low friction piston rings allowing oil by and burning it
Does the 0w30 not have esters?Your oil control rings might be plugged up with gunk and carbon, and that's the worse assumption on my part. Running 5W-30 by itself won't change much. If you want to go that route, I recommend running an OCI of Mobil 1 FS 0W-40. It's basically a 5W-30 but it contains some mild cleaning power in the form of Esters. Red Line 5W-30 would be another option, but that one is expensive.
Mobil 1 AFE 0W-30 is formulated with Alkylated Naphthalenes instead of Esters. Mobil does that to increase the effectiveness of anti-wear additives so they can decrease the amount of ZDDP used to give AFE the ability to provide a tiny bump in fuel economy. It's a bit more complicated than that, but that would be the dumbed-down version.Does the 0w30 not have esters?
Those are all excellent possibilities. Leaky valve stem seals, maybe? I guess the easiest thing to try is to clean the engine first.It's likely caused by mechanical issues and/or sticky piston
rings, maybe weak valve guides or a broken PCV system.
My wife's Outback also consumes the Subaru recommended 0W-20. I had considered switching to 0W-30, but also found it hard to find. Since I use M1 FS 0W-40 in my E350, I decided that I will be filling the Outback with M1 FS 0W-40 at the next oil change. I'm anxious to see if it slows down the oil consumption.Your oil control rings might be plugged up with gunk and carbon, and that's the worse assumption on my part. Running 5W-30 by itself won't change much. If you want to go that route, I recommend running an OCI of Mobil 1 FS 0W-40. It's basically a 5W-30 but it contains some mild cleaning power in the form of Esters. Red Line 5W-30 would be another option, but that one is expensive.
I always find it intriguing on these various forums how experiences vary from person to person…?Honda 2.4's are known to consume oil. Honda went through a period where their low tension rings were causing oil consumption issues.
