I just bought a 2024 Silverado Custom trail boss 5.3L V8 Z71 4x4. This truck uses Dexos 1 Gen 3 0W20 oil, 8 quarts of it.
It has start/stop but I turn that off every time I get in. Plus, being in south Florida with the A/C running full blast, it practically never start/stops anyways. I don’t know if this engine has the cylinder deactivation feature that turns the 8 cyl into a 4 cyl on the highway. How do I know if that feature is installed?
My question? Can I run 0W30/5W30 in this engine? Or is 0W20 a must?
There is a lot of chatter about stuck lifters causing damaged camshafts in these engines, but mostly from a few years ago. Not sure if that is still an issue or not?
A GM mechanic I know says to change the oil religiously every 4000 miles on these. I thought that was excessive with the 8 quart sump.
