0w-30 HM?
hi! ive got a ford 4.0 sohc 300k miles. would you reccomend switching from the factory 5-30 to a 0-30? Ive found some but none in the HM flavor. would you reccomend switching to a 5-40 or 0-40 too? theres a couple monor leaks so thats why i use HM. also ive heard sometimes diesel oil is good? lastly, what oil filter would you reccomend? i used the fram ph8a previously but seeing some youtube videos has made me wonder if that was a good choice...
I dont believe a High Mileage 0w30 is on the market.
5w30 High Mileage many to choose from
I have a 1998 Explorer with the SOHC 4.0L engine that is just under 300,000 miles. Put Mobil 1 0w40 in, submit for the rebate, and sleep well.
Diesel oil is sometimes used in high performance gasoline engines where it sees more stress, but it ain't High Mileage oil. I've never seen High Mileage oil as 0w-XX. Usually it's 5w-XX or 10w-XX. If it's burning little to no oil and sounds smooth, I'd just stick with 5w30. Go 10w-40 if it does have those problems.
I'd take a look at Pennzoil High Mileage, Pennzoil Platinum High Mileage, or Mobil 1 High Mileage with a standard Wix oil filter. My personal favorite High Mileage oil is Royal Purple High MileageX for reducing piston slap noise I had in my LS, but its pricey.
That engine was one of the exceptions Ford found didn't do well with 5W-20. That makes me suspect thicker might be better in that application. I would use 0W-40 if I needed to do -20F cold starts. In the south where I live it would get Mobil 1 10w30 HM which is a 3.5 HTHS like a A3 Euro 30.
Our 4.0 Mustang always gets 10W30.
I thought I remember reading years back that the Cologne 4.0L that was put in the Explorers for many years was engineered from Germany and specifically to use a 5w30 oil. I know when my 2006 started using some oil in between its 5k OCIs -- I jumped up to 10W30 and that eliminated oil consumption until I sold it with 180,xxx miles.
I suspect it was a 3.5 HTHS 5w30 given the location and time but I have no proof only supposition.
