Lab results from my experiment with High Performance Lubricants Engine Cleaner 30W, ran it for 568 miles of this short 1,732 mile OCI before the oil became extremely black (as expected given the engine's poor maintenance history w/ the original owner for 162K miles). This despite > 80K miles of various synthetic High Mileage oils, a few runs of Valvoline MaxLife syn blend, Shell Rotella T6, and diligent OCIs.
Iron may be artificially low as I have a FilterMag and 6x neodymium disc magnets on the oil filter and it showed metal paste on the can when opened as shown. HPL recommends 2K miles with their Engine Cleaner, I dumped the oil early out of concern for timing chain wear due to dissolved sludge abrasives...this may or may not have been necessary (no lab measurement of microscopic carbon abrasives known to cause wear at the pins & bushings?).
The most surprising change was the oil filter contents...no solid bits of sludge in the can as I've consistently seen in the past. The EC appeared to have worked as advertised, dissolving the crud and keeping it suspended in solution. I flush the pan every other oil change and consistently get solid sludge particles (lay a paper towel across the oil drain surface as a filter, see pic 3 for the pan flush results prior to this oil fill)...will do again after the current OCI is done.
It's unclear why the Flash Point was lowered, given the HPL stuff is not a "solvent" as Blackstone assumed. No indicators that the fuel injectors are leaking, LTFTs are in the +0.78% to +2.34% range and balanced within +/- 0.78% bank to bank.
Note that the 184,621 sample was the oil change after replacing the timing chains, sprockets, etc. with new Toyota parts, accounting for the high wear metals.
