07 Mazdaspeed 6 Factory Fill
CO
Engine 2.3L Turbo, direct injection
Miles on engine 1274
Miles on oil 1274
Date sampled 10/16/07
OEM Filter
OEM Oil ?5w30?
Iron 14
Chrom. 0
Lead 0
Copper 187
Tin 0
Alum. 5
Nickel 0
Silver 0
Silicon 59
Boron 6
Sodium 0
Magne. 19
Calcium 1706
Barium 0
Phosph. 944
Zinc 1044
Moly. 100
Titan. 0
Vana. 0
Potas.0
Fuel Visc @40c N/A
Visc @100c 9.06
Water 0
Soot/Solids N/A
Coolant 0
TBN 4.84
Oxid. N/A
Nitr. N/A
Comments: "Copper and Silicon levels high-Possibly from normal engine break in. No corrective action required. Oil is suitable for continued use. Resample at next regular interval."
Other than what is noted the viscosity sticks out to me. If this is a 30wt oil then Id quess it mechanically sheared horribly or the fuel dilution test was errant and there is chemical shear. I guess it could be a 20wt from the factory.
Car is driven 25 miles one way each day typically, when its driven, taking between 20-30 minutes to destination. RPMs averaging probably about 3-4K. Warm ups until the coolant needle moves into the operating area and cool downs of 1.5 to 2.5 minutes depending on ambient temp.
Originally Posted By: benjamming
What lab?
Anyone know the factory fill vendor & flavor on this?
There are getting to be a lot of DI engines.
Sorry. Lab was Oil Analyzers, Inc.
Car was built in Japan, not sure if that helps ID the OEM oil.
Originally Posted By: Gary Allan
Did I miss a flash point?
You didnt. OAI does not test for that.
Originally Posted By: Scott P
What oil did you use for the oil change?
Had a free oil change from the dealer who put in MC 5w30. I will have this changed or change it myself at the 3K mile mark, oil will have approx 1726 miles on it, and take another sample.
