19k miles on it. Everything works good.
just bled the brakes with some dot 4 racing fluid and its a night and day difference.
Im looking to change the power steering fluid next and the ATF as well.
Been looking at Royal Purple/Amzoil/REdline power steering fluid and not sure if i should get one of those or OEM stuff?
As far as the transmission, i think i want to use the OEM Z-1 fluid.
Either way i dont want to do drain and refills for the PS or ATF.
i was wondering if its ok to get the PS out by disconnecting a line and letting the old fluid pour out while adding new fluid?
same goes for the ATF
i know where my trans lines are... can i just connect 2 lines and have the fluid in a bucket and the fluid will exchange?
i work at jiffy lube and have a ATF matching that does that put i don't want to use the fluid we have...
