Originally Posted By: 86cutlass307
If it has the A750E or F, it will have a traditional semi-flat style metal filter with O-ring seal, held by 4 small bolts (torque is 7 ft/lb) I uncrimped the seam on mine to inspect some time back and did not find anything worth mentioning. It will have an extremely fine mesh layer as the filter. You will probably find a grey film covering the inside of the pan and filter body with 4 magnets on the pan bottom. If you do drop the pan, get a Toyota pan gasket, cost a little more but worth it. (Pan bolt torque is 39 inch/lb.) Perfect time to do a cooler return line fluid change (if that's what you mean by flush) I am from the school that removing the pan, cleaning the crud and clutch residue out is good preventative maintenance. Over time, debris and grit can't do anything good inside your tranny.
Send me a PM with contact info and I can email pic's of what you will find when you open that thing up.
Thanks for the pics. You mentioned going with the Toyota gasket, did you also buy the Toyota filter or aftermarket?
I used an aftermarket filter, Toyota contracts their production out then jacks the price sky high on their filter. The filters available seem to all be the same, a very fine mesh to catch debris. My sister has a Rav4 and some of the available filters for those are the paper/felt type media, I read about some problems with that type though.
My son in law has an '07 4Runner with the same tranny, he purchased an aftermarket kit and the gasket was rubber. It's just my preference, but I don't like the rubber gaskets. Too likely to deform and easy to overtorque and deform the pan rail and leak. I had a spare OEM gasket so we tossed the rubber gasket. I made 3 passes with the torque wrench when tightening the pan bolts to stabilize the torque and all is well on my truck and his 4Runner.
How do I determine what type auto transmission my truck has?(750A, E?) I do not see anything in the owner's manual or Haynes Manual regarding the Transmission Model.
