Here's an UOA I had done awhile ago. I found it interesting that Ford now recommends 5k OCI but looks like my truck will not make that mark. Let me know what you think.
Blackstone Report:
No problems showed up in the initial sample from this engine. All wear read right around averages after 3,783 miles use on the oil. Universal averages show typical wear from Ford's 5.4L V-8 engine after 5,600 miles use on the oil. Silicon was average at 10 ppm, showing no problems with the air filtration/induction system. The TBN read 2.2, showing some active additive left, but not a lot. 1.0 is too low. We like the oil use interval of ~3700 miles for the way this engine wears and suggest sticking with it for now.
Code:
2005 Ford F150 5.4L 3valve
OIL Motorcraft blend 5w20
Fliter: pure1
MILES IN USE 3783
MILES 23,050
SAMPLE TAKEN 4/27/07
ALUMINUM 3
CHROMIUM 1
IRON 22
COPPER 2
LEAD 0
TIN 0
MOLYBDENUM 43
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 215
SILICON 10
SODIUM 3
CALCIUM 1975
MAGNESIUM 30
PHOSPHORUS 704
ZINC 826
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 380
SUS VIS 210ºF 50.3
cSt @ 212ºF n/a
Blackstone Report:
Code:
Fliter: pure1
MILES IN USE 3783
MILES 23,050
ALUMINUM 3
CHROMIUM 1
IRON 22
COPPER 2
LEAD 0
TIN 0
MOLYBDENUM 43
NICKEL 1
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 215
SILICON 10
SODIUM 3
CALCIUM 1975
MAGNESIUM 30
PHOSPHORUS 704
ZINC 826
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 380
SUS VIS 210ºF 50.3
cSt @ 212ºF n/a
