Originally Posted By: SteveSRT8
Odds are you're losing HP to that oil. In my old Neon R/T just changing from a 40w to a 30w was worth about 4-6 hp at 7600 rpm.
BTW, how do you over rev unless you muck up a downshift? Even the old track rat neon had a rev limiter, stock was 7300.
ECU can be reflashed, stock redline is 6200rpm due to a rod-to-stroke ratio of 1.43:1
The K24 has an R/S ratio of 1.54 (152mm rod, 99mm stroke) and the factory redline was up to 7,600rpm (K24A2).
Not much better
Yeah but the QR25 has the lowest rod-to-stroke ratio of any production engine. Also my engine was revved past 8000rpm several times, wayyy past the 6200rpm redline, I didn't expect this engine to live very long after using it for drag and rally! It even has the balance shafts removed and solid mounts.
But 130k miles later it doesn't even burn a drop of oil! It has wayyy surpassed my expectations and still continues to deliver excellent UOAs!
I think GM's 400SB had a lower R/S ratio, but I could be wrong. It has been many years since I've done the math
