It's an old 14hp Cast Iron Kohler K321. About 100 hr on a rebuild. Plows for about .75-2 hours a snow event. Usual temperatures are 20-30 degrees F, as I try to get it cleaned up before the real cold sets in after the storm. Sometimes I have to run it from 0-20F, but only a few times a year. It sleeps in an unheated garage I'd guess about 25-35 degrees, but sometimes I leave the door open like a dummy & it starts from a colder ambient.
I run delo 15w40 in the warm seasons in it.
I was going to fill with my on hand 5w40 Rotella T6, but after looking it up, that's a THICK oil. (Like 14.x cst IIRC) so I had second thoughts. It's air cooled, and well shrouded. With the low ambient temperature, i wonder if it'd even hit 100c running. The motor is Spec'd for straight sae30 over 32 degrees, and 10w30 0-32 degrees with the (possibly old skool) caveat that it will consume from Kohler. Does that seem kinda thick & too far off spec for a splash luber?
So I jumped on BITOG, and wasted hours of my life lurking, and had mostly concluded GC 0w30. But I don't think that exists any more? Then I thought about M1 HM 5w30, or Rotella T5 10w30, but the are both super low cst IIRC, like [email protected]? This thing runs rich & probably shears oil like a sheep. Doesn't that seem pretty low vis?
Now I'm just lost & confused. Over analysis paralysis! Please help! (God I wish I could get GC 0w30!)
What's the best 0w / 5w HEAVY 30wt?
Is the 5w40 T6 really too heavy as I figure? I like that oil, and have it on hand. Maybe I should just dump that in
I'd prefer some good Zn / strong add pack for the old skool flat tappet design.
What would you guys recommend for a winter fill?
Sorry for the novel. Thanks for your time!
Max
