- Joined
- Dec 7, 2021
- Messages
- 4
thanks for the add- I have an 04 Jeep GC w/ 4.0. It suddenly began missing and my code reader said it was p352 ignition coil B primary/secondary circuit. Soooo since the Jeep has 165K on it and I do not know its history- I replaced all the plugs, the coil rail (all the coils are made into), all the injectors, the fuel filter and air filter. IT still is missing and throwing the same code. I did pull the plugs after firing it up for 2-3 minutes and #4 was blackened heavily so did a compression test- all cyl are about 160. I am at a loss as to where to look next-
One other thing to note- since I have had it (about 4 m)- to crank it up, you have to turn the key on, give it a moment then start it. If you dont give it that moment- it will just spin over and not start..
Help!!!
Help!!!
