Chasing my tail on this and was hoping to get some guidance. The car stutters or misses. Started about 2 months ago. It only misses after car is up to temp. Runs great cold. No codes. Only noticed it in 4th, 5th and 6th gears with slight acceleration under load (going up hills) under 2500 rpm’s. Usually just one stutter but occasionally multiple. Thought maybe transmission. It is the Aisin F21. I drained and filled with proper T-IV fluid which is listed on the dipstick. No results. Car shifts great and no misses if I get on throttle. I cleaned The MAF sensor and the throttle body. I tried running premium gas. I replaced all 6 coils with correct Motorcraft DG-520 coils 2 weeks ago. I took it for a drive and at mile 5 started missing terribly and threw codes. Misfires in cylinders 3 and 4. What the heck? Had to take air intake back off and then replaced new coils with two old coils. Codes stayed away but still missing under slight acceleration after it gets warm but been driving the car daily for 2 weeks. Tonight on way home from work it started missing more frequently and threw a code that cylinder 6 is misfiring. Ready to give up and take to dealer but thought I would ask here before making an appointment. Car has 130k on it. Replaced plugs 2 years ago at 100k. Also replaced pcv valve when I did the coils. Air filter is clean.
