'03 Kawasaki Vulcan 1500 - Motomaster 10W40 - 2Kmi
Ontario, Canada
Analysis #2 on this oil. Oil sampled hot.
Fuel still seems high although this may be normal for this engine. Shearing and fuel munched this oil down to a 5W30 in just 2K miles. Oil dumped and replaced with Shell Rotella T 15W40.
Code:
2003 Kawasaki Meanstreak 1500 (1500 V Twin)
27,800 km on engine (17,300K miles)
3,200 km on oil (2K miles)
Canadian Tire Motomaster Formula1 Premium Motorcycle oil
10W40 - made by Shell Canada
Analysis by Fluid Life, Brantford, Ontario
July 7, 2011
VOA 1000 miles 2000 miles
Sodium 0 0 0
Potassium 0 0 0
Silicon 28 15 14
Aluminum 0 4 6
Iron 1 15 24
Copper 0 8 11
Lead 0 0 1
Tin 0 0 0
Chromium 0 0 0
Calcium 2185 2073 2056
Zinc 1016 982 979
Phosphorous 858 805 808
Magnesium 10 22 23
Moly 81 75 73
Boron 163 140 122
Lithium 1 1 1
Fuel 0 1.44% 1.51%
Cst@40C 101 80 77.6
Cst@100C 15.1 12.8 12.2
VI 157 159 155
Oxid.(A/cm) 0.1 1.38 2.18
Nitr.(A/cm) 0.1 2.91 4.32
Sulf.(A/cm) 0.1 0.1 2.70
There's only one other UOA for a Vulcan 1500 motor on here that I can find so it's difficult to say if the wear numbers are normal or not for this motor. Here's the other UOA :
UOA Post 2096685
BTW, the 1500 motor in the Kawasaki Meanstreak differs slightly from the 1500 installed in all the rest of the Vulcan series (ie Nomad, Classic, etc) :
1)Larger throttle bores
2)Larger intake valves
3)Different cam grind/valve timing
4)Different fuel mapping (this is a FI engine)
5)Different gear ratios in the transmission (all gears). This is a shared-sump engine.
I wouldn't expect any of this to result in a significant difference in UOA compared to the standard Vulcan 1500 engine, but I thought I'd mention it.
Also, I can regularly get 50+ mpg on this machine with easy, steady cruising on rural roads at 50 - 60 mph
1.51% fuel is going to kill the viscosity. until you get that to zero the vis numbers are worthless except for showing that you still have a fuel issue.
iron of 24 and copper of 11 maybe high for 2k or normal. we need a trend to form.
That's what makes then 'not worthless' to me : knowing that at 2K miles (or less) I'm running the equivalent of a 5W30, and therefore the oil needs to be changed by then (rather than blindly running to 3K or 4K miles). And as you say, knowing that fuel is responsible for probably a good portion of the VI loss is useful too. I need to check crankcase ventilation, compression and look for possible leaky injector.
Yea, I wish there were more UOA on these motors so we had some idea what 'typical' is.
My Chrysler 2.7L V6 produces less than half that much iron and copper during a 5K mile run. But then that's 'typical' for that motor.
Thanks for your comments BTW
