Took my new (used) escape to the shop the other day and it apparently has a rear main seal leak, front valve cover leak, and a couple other seals might be leaking. They quoted me over $2300 in labor alone so I do not think I will be having them fix this problem. Most of the leaking started after changing the oil. I used valvoline conventional. Is there a particular kind of oil I should try next? Should I try auto-rx? I'd like to be able to continue to drive this vehicle for a while if possible.
Thanks for any advice.
