Originally Posted By: Mark888
Originally Posted By: chevrofreak
It's basically an oil. It's made up of 3 esters. It just has no other additives like zinc or moly, so it's more like an oil base stock before the AW additives are introduced.
Adding 4oz of pure PAO do your oil wouldn't be the same as using an additive, would it?
Basically? Are you sure it has no other additives? Absolutely none?
Would you be willing to fill your entire crankcase with it?
Would an auto manufacturer classify it as an additive? (yes they would).
If one uses a synthetic on a relatively new engine, there is absolutely no reason to use Auto-Rx.
You made a definitive statement that AUTORX would void a warranty. You are dead wrong per the Magnusson-Moss act. I provided you that info. So this discussion is silly. As for the OP. I doubt he would benefit from a full blown AUTORX clean/rinse but a maintenance dose will not void his warranty.
I have seen sludged engines with Mobil 1 in them. Was it Mobil 1's fault? Of course not. It was faulty PCV or ridiculous 25K OCI's (where did they get that silly idea I wonder?)...AUTORX will clean a "dirty" motor better than a synthetic motor oil.
I think what your crusading about is Mobil 1 will keep a clean motor clean. That is fine. But don't tell people using any additive will automatically void their warranty because that is a flat untruth. Like saying if you put a Amsoil Air Filter in your new car the warranty is voided. Just not true.
