Hi all,
So I posted a while back about my 2002 Alero with the 3.4 and 4T45E transmission. I dropped the pan and changed the filter at 150k miles and replaced 7 quarts of rotten old Dex3 with MaxLife. All seemed well and shifts had improved quite noticeably.
The other night, a cooler line loosened off or backed off enough that it contacted the fan and burst, spraying ATF all over the engine and causing complete transmission failure/shutdown. A shop completed an emergency radiator replacement and cooler line replacement a few months ago away from home and I think they may have installed one of the lines poorly. It was raining and dark so I couldn't see the ground, but I could smell the fluid burning on the engine and exhaust. I coasted it into a small village where I pulled over. Wouldn't go in any gear, totally done. I didn't know about the cooler line until later. I feared the tranny had just cooked itself (though with no warning at all).
Do you guys think it could survive total fluid loss like that unharmed? I'm worried that if I refill with MaxLife and go, it may be permanently damaged by the loss of coolant and will fail sooner rather than later.
Thoughts?
Thoughts?
