Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
96 registered members (A310, AndyB, 65convertible, 2009Edge, 16HC, 12 invisible), 1,676 guests, and 41 spiders.
Topics290,783
Posts4,850,217
Members66,036
Most Online3,590
Jan 24th, 2017
Page 2 of 5 1 2 3 5
Re: I need the best penetrating oil [Re: porcupine73] #810785
05/31/07 07:44 PM
05/31/07 07:44 PM
Michigan
knealeski Offline
knealeski  Offline
Michigan
I prefer Kroil, but generally can't find it unless I order from Kano. PB Blaster works similarily. I have no BTDT yet but will soon on a 50-50 mix of Automatic Transmission Fluid (ATF) and Acetone. I read somewhere that that required less torque to loosen stuff than Kroil and PB Blaster. The melted wax trick also works, but I'm going to explore the ATF approach where I can't use heat.
Re: I need the best penetrating oil [Re: knealeski] #810786
07/07/07 03:45 AM
07/07/07 03:45 AM
JAX
M104-AMG Offline
M104-AMG  Offline
JAX
+1 on Kroil or Aero Kroil
Goto www.kanolabs.com and you'll see lots of offers, including some great bundles or 2 for 1's.
:-) neil
Re: I need the best penetrating oil [Re: M104-AMG] #810787
07/07/07 05:58 AM
07/07/07 05:58 AM
Buffalo, NY
porcupine73 Offline
porcupine73  Offline
Buffalo, NY
Yes I like that Kroil too. I've tried a couple other products as well. I put some info about penetrating oils here including many of the products from this thread, plus a special mix.
Re: I need the best penetrating oil [Re: Maximumcanon] #810788
07/14/07 07:26 PM
07/14/07 07:26 PM
North Texas
63Avanti Offline
63Avanti  Offline
North Texas
advice here is sound, though I have not tried the honey bee wax notion. I would bite the bullet and buy Kroil direct from Kano. Like BG products, it is excellent but tough to find. Personally, I alternate between PBlaster and Kroil while disassembling my 63 Avanti, it is not clear which is better.
it is "mileage" not "milage"
*cure for common mid-life crisis*
Re: I need the best penetrating oil [Re: 63Avanti] #810789
07/17/07 12:26 PM
07/17/07 12:26 PM
CA
gtx510 Offline
gtx510  Offline
CA
I've use PB Blaster and it's better than most penetrating lubes. I'd like to give Kroil or Knock'er Loose a try, the Datsun guys have always said Kroil was good..
LC20 + ATF?
http://www.lubecontrol.com/reports.htm
Quote:
4.1 Penetrating oil. I mixed by volume, 70% LC20 and 30% synthetic Dexron III ATF to produce an optically pleasant and very effective penetrating oil. I applied this mixture to muffler and tail pipe clamps. Rust and corrosion products immediately dripped with the solution and once the nuts were removed, the threads of the bolts were like new. The remaining oil tenaciously clung to the assembly to protect it from rust.
Re: I need the best penetrating oil [Re: gtx510] #810790
07/31/07 02:14 AM
07/31/07 02:14 AM
Minnesota
junebug Offline
junebug  Offline
Minnesota
I have a can of Knock'er Loose. It's good,but not fantastic. It did not work on rusty exhaust clamps.
Re: I need the best penetrating oil [Re: junebug] #810791
08/07/07 04:49 PM
08/07/07 04:49 PM
washington, dc
chas3 Offline
chas3  Offline
washington, dc
i have a can of kano sili-kroil that i really like. kroil and silicone in an aerosol. the tag line on the can says it gets into "infinitely small spaces". its almost true.
Re: I need the best penetrating oil [Re: gtx510] #810792
08/07/07 04:53 PM
08/07/07 04:53 PM
MO
obbop Offline
obbop  Offline
MO
Have heard several experienced mechanics over the years exhort the wonders of the OB Blaster previously mentioned.
That wax trick sounds plausible.
Heat is a well-known portion of the get-the-frikken-nut/bolt-loose equation.
National Master-at-Arms
Student Revolutionary Strike Force
Re: I need the best penetrating oil [Re: Maximumcanon] #810793
08/21/07 05:50 AM
08/21/07 05:50 AM
TN
HyperJinx Offline
HyperJinx  Offline
TN
Quote:
Tihnk PB Blaster will help a seized car lock? safe on auto paint?
It is NOT safe on auto paint.
2007 Corvette (Synpower/M1 filter) 2001 Silverado (Syntec Blend/ PureOne) 1969 Camaro (Rotella T/Napa-Wix)
Re: I need the best penetrating oil [Re: gtx510] #810794
08/21/07 11:52 PM
08/21/07 11:52 PM
Michael_P Offline
Michael_P  Offline
Okay, it might not be the best pentrating oil, but it works well and has good lubricity and works well on fighting corrosion, try JB-80. (Justice Brothers). I have used this from anything from cars to guns to bicycles. I think it's the best jack of all trades sprays.
Re: I need the best penetrating oil [Re: smeltjr] #1036684
11/28/07 02:34 PM
11/28/07 02:34 PM
Wisconsin
boomtower Offline
boomtower  Offline
Wisconsin
I some times use a product from kimball midwest called, Torq"CB" Corrosion Blasting Penetrating Oil. Some other good ones that I tried are: PB Blaster, Jb 80,
Re: I need the best penetrating oil [Re: smeltjr] #1066823
01/17/08 04:23 PM
01/17/08 04:23 PM
Michigan
John-r Offline
John-r  Offline
Michigan
PB Blaster gets my vote, great stuff.
John
All my toys need oil!!
Re: I need the best penetrating oil [Re: John-r] #1067866
01/19/08 04:54 AM
01/19/08 04:54 AM
Wylie, Texas
hi-miler Offline
hi-miler  Offline
Wylie, Texas
Just tried wax. Worked great! Had a Troybilt rototiller with both wheels rust welded on due to being out in the rain. These are the type that have a removable pin and two positions for the wheel.
It gets my vote.
If I wake up, it's a good day.
Re: I need the best penetrating oil [Re: chas3] #1069871
01/22/08 02:05 AM
01/22/08 02:05 AM
Owego, New York
Gillsy Offline
Gillsy  Offline
Owego, New York
I've used WD-40, Liquid Wrench, and PB Blaster. SiliKroil excelled where the others failed. It costs more, but it does perform.
Many are the afflictions of a righteous man
2018 F150 Supercab 2.7 Ecoboost 4x4
400 lbs/ft of grin at 2750 RPM
2016 Kawasaki 650 Versys LT
Re: I need the best penetrating oil [Re: Gillsy] #1069881
01/22/08 04:57 AM
01/22/08 04:57 AM
Texas
Throckmorton Offline
Texas
No love for 3 in 1 oil?
Page 2 of 5 1 2 3 5
