My '96 Honda Accord owner's manual lists:
2.4 liters/2.5 U.S. quarts, and
2.7 liters/2.9 U.S. quarts for a fluid change
(2.2 liter I-4 engine and 2.7 liter V-6 engine respectively);
6.0 liters/6.3 U.S. quarts, and
7.1 liters/7.5 U.S. quarts total capacity
The fluid Honda specified in 1996 was either, "Honda Premium Performance Automatic Transmission Fluid or an equivalent Dexron II Automatic Transmission Fluid (ATF) only." (direct quote from page 159)
There is NO oil pan. There is no user serviceable transmission oil filter. (a screen, though, but only accessible by disassembling the transaxle) There IS a drain plug with a 3/8" square hole screwed into the cast aluminum transmission case and it DOES have an aluminum washer. I found on mine, contrary to what Honda says, that the washer can be reused without leakage, but, better have a new one handy just in case. They're around $2.00 (maybe more now) at Honda dealers.
[ January 26, 2004, 09:18 PM: Message edited by: Ray H ]
