Seen several threads about this stuff but no hard facts. Saw some in Advance Auto yesterday so I thought I'd see if any information on composition could be obtained. Messaged Coastal from their web site and got the MSDS. Here's what it says:
[ October 21, 2003, 01:50 PM: Message edited by: doyall ]
Product info sheet says this:quote:
code:
COMPOSITION
Occupational Exposure Limits*
OSHA ACGIH
Product CAS Number Wt% PEL TLV Other Units
Coastal Synthetic 75w140 Mixture 100 N.A. N.A.
Ingredient(s):
Solvent Refined 64742-62-7 7[%] 5 5 10 STEL mg/m3**
Residual Oil
P. A. O. Synthetic base oil Mixture >85[%] N.A. N.A. N.A.
Additives containing N.A. 5-8[%] N.A. N.A. N.A. N.A.
polymers
Looks to be a true Group IV lube. I think it was $5.99/qt (compared to $7.99/qt for M1). Any thoughts?quote:
Coastal® HD FS 75w-90 Gear Oil is a full synthetic gear oil engineered to meet the severe high-load and hightemperature demands of contemporary race and commercial vehicle differentials and transmissions. It possesses excellent load carrying ability, extreme pressure (EP) properties, wear resistance, low temperature performance, oxidation stability and protection against rust and corrosion. Coastal® HD FS 75w-90 Gear Oil is recommended for make-up and complete refill of all passenger car, light truck and heavy-duty differentials, transmissions and steering gears, including limited slip
differentials.
Coastal® HD FS 75w-90 Gear Oil meets or exceeds the following lubrication and performance requirements: API MT-1 and GL-5; MIL PRF2105E; Meritor Automotive, Inc. (formerly Rockwell) 0-76-E (petroleum) and O-80 (synthetic); Eaton PS-037, PS-109, and PS-163; Eaton Extended Warranty; Dana Corporation, Axle Division; Mack GO-J and GO-J Plus; Navistar TMS 6816.
