Brightest backup light for my daughters car?
Originally Posted by rooflessVW
Reverse lights are an indicator to those around you. Blasting super bright light everywhere while in reverse will do little to alleviate the problem.
If it's that big an issue, I reccomend installing a backup camera.
+1
The LEDS will help.
Most backup cameras need light to work, and even some OEM backup cameras are worthless for backing up a vehicle. There is only so much that narrow view from the trunk can tell you. Nothing beats turning your head around.
My brother has LEDs in the reverse lights on his Tahoe. I was standing behind the truck the other night when he remote started it and unlocked the doors and I couldn't believe how much light they gave off. Absolutely enough to back up by. My Suburban still has the stock bulbs and I see well enough with them but if they ever need to be replaced I'm going LED.
I have lights by a company called Diode Dynamics on my truck. Basically all bulbs I have are from them now, except my HIDs.
Looks like these will fit - https://www.diodedynamics.com/backup-leds-for-2005-2008-pontiac-grand-prix-gxp-pair.html
I have the XP50, looks like the XP80 is the brightest for your application. Pricey at $90, but I love the reverse bulbs in my truck.
Check out a couple of pictures here - https://imgur.com/a/rk7Zu. I can try to take some night shots as well. They're bright enough to help me see, and help others see that I'm backing up, but they certainly don't blind anyone.
I live in the country and have a driveway a little over 200’. I’m able to turn around which makes it a non issue. If it was an issue, I would install wired low voltage lights. Toro still make them?
$90 USD is a stupidly high price for 2 back up bulbs, sorry...
