It sounds like you purchased a vehicle that perhaps was not well maintained when you bought it.
I would not worry about a slight valve tick on cold starts. Unless there are actual drivability issues. I agree with others if it bugs you, go up one notch in oil viscosity.
To me the transmission is the only wildcard here. A certain percentage will fail young no matter how reliable the average is. I agree do the old school drop pan and change transmission filter first. You sound pretty handly.
The rest of it though is just wear items tires/brakes all cars have these. The spark plugs are work on them but then you are good for another 100,000 miles. Your maybe can go quite a bit longer. Unless you are getting CEL light or drivability problems -- keep the spark plugs for a year. Tires and brakes as we know, are wear items on all vehicles. No getting around it. That should not factor in because you are going to pay for tires and brakes one way or another, both in lower resale value and your having to pay more for another car that costs more money but has newer tires and brakes. Anyway you can do breaks and exhaust yourself and you already did the timing belt/water pump.
I would keep it especially if you are underwater on it.
