should read "the last 2 had lasted 3 years."quote:
Originally posted by Gebo:
because the last 3 had lasted 2 years.
[/QB]
Thanks for clearing that up for me. That makes since.quote:
Originally posted by blano:
Flashpoint is only posted for shipping purposes. It basicaly only tells you at what point the dilluent burns at so it really has no bearing on a oils high temp capabilitys.
Hirev-it did seem that castrol tried to pull one over on use with that deal. Although they won there case against mobile.quote:
Yes, it can be run at about any ratio.quote:
Originally posted by harrydog:
Can the Mobil 1 MX2T be run at 50:1?
I've been running it at 40-1 with excellent results. It easy to mix that way too. A 1 pint bottle to 5 gallons of fuel...quote:
My seadoo specifically says not to use TCW3 oil. It asks for the 1st generation (TC-W) oil with higher ash in it. I just use the Seadoo/Bombardier oil, which is about $15 a gallon. Was thinking of going to the Amsoil injector lube but really the SD oil works fine so I'll stick with that.quote:
Originally posted by Cujet:
By the way, it meets EGD and API TC requirements. So, use in a SeaDoo engine is OK as far as warranty is concerned.
Chris
