Originally Posted By: ZraHamilton
"Group III base stocks contain greater than or equal to 90 percent saturates and less than or equal to 0.03
percent sulfur and have a viscosity index greater than or equal to 120 using the test methods specified in
Table E-1."
All group I, II, and III base oils are refined from crude oil. Group III+ oils (GTLs), are derived from natural gas. Group III base oils meet the definition above and they all come from the EARTH, like I said before.
There is no such thing as Group III+ base stock, even though entities sometimes use that designation it does not exist in API 1509 Appendix E. But even when using that designation it isn't only GTL products that are "Group III+". Other high VI base stocks that aren't a Group IV or V also carry that unofficial designation. For example, Visom was not GTL but it was called Group III+ by ExxonMobil:
https://www.exxonmobil.com/english-GB/Basestocks/pds/GLXXVisom-Series
The actual (not imagined) definitions in API 1509 Appendix E for the different groups does not use the word "earth" anywhere, nor do they indicate the origin of the material. Only those material specifications that are listed in the document are relevant to the purpose of API 1509 Appendix E.
Quote:
E.1.2.1
A base stock is a lubricant component that is produced by a single manufacturer to the same specifications (independent of feed source or manufacturer’s location); that meets the same manufacturer’s specification; and that is identified by a unique formula, product identification number, or both. Base stocks may be manufactured using a variety of different processes including but not limited to distillation, solvent refining, hydrogen processing, oligomerization, esterification, and rerefining. Rerefined stock shall be substantially free from materials introduced through manufacturing, contamination, or previous use.
