No Poly-tics :) Rambling On
by Zee09. 10/20/18 08:10 AM
Michigan Police Vehicle Test Results
by tenderloin. 10/20/18 08:04 AM
1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
Repainted hood- when is it safe to wash and wax?
by PlzRepond. 10/20/18 01:23 AM
75w90 vs 75w140
by SnowDrifter. 10/20/18 12:38 AM
Wash and Spray Wax
by Marco620. 10/20/18 12:05 AM
Marine fuel injection musings
by OVERKILL. 10/19/18 09:45 PM
Finding a new mechanic
by AZjeff. 10/19/18 09:30 PM
Castrol Stop-Start oil
by Silver. 10/19/18 09:13 PM
5.7 vortex Fresh air hose?
by Serolim. 10/19/18 09:11 PM
New Oil Refiner (Frantz) purchased from Ed
by FlyNavyP3. 10/19/18 08:45 PM
1988 Dodge B250 Conversion Van Shocks?
by petes67bird. 10/19/18 08:44 PM
20KW Standby Generator Recommendations
by MParr. 10/19/18 08:15 PM
2003 Diamante, SHU 5W40, 6817m OCI
by Spetz. 10/19/18 07:48 PM
Can you tell a difference between a 305 and 350
by ram_man. 10/19/18 07:45 PM
Changing Fuids
by Snagglefoot. 10/19/18 07:38 PM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
76 registered members (atikovi, 2003f7, alarmguy, Blueskies123, AZjeff, 9 invisible), 1,477 guests, and 27 spiders.
Topics292,212
Posts4,876,146
Members66,249
Most Online2,494
Oct 17th, 2018
Mechanics advice on 5.9 Dodge Magnum #4633476
01/13/18 11:25 AM
01/13/18 11:25 AM
California
mbacfp Offline OP
mbacfp  Offline OP
California
My trusted mechanic thought I should try running Castrol GTX 20w-50 instead of 10w-30 to see if that helps with some oil consumption first before assuming a plenum intake manifold gasket problem. I am thinking high mileage oil instead (10w 30). What do you all think? Thanks again for the advice and help.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633493
01/13/18 11:36 AM
01/13/18 11:36 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Gotta fix the issue. If it's sucking oil, grade won't do much ...
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633494
01/13/18 11:37 AM
01/13/18 11:37 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I think you should just fix the dang gasket already (after verifying if that is the problem)
Do you know what "troubleshooting" pertains to?
It sounds like you just want to change stuff....
....not find out what the REAL problem is.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633501
01/13/18 11:39 AM
01/13/18 11:39 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Your trusted mechanic needs to diagnose things instead of using the method known to elementary school math teachers as "guess and check".
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633506
01/13/18 11:43 AM
01/13/18 11:43 AM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Yes, I am a little surprised as well. Maybe caught him on a bad day. Will order the Hughes Kit and be done with it. Thanks for the advice and time. Really appreciate it.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633585
01/13/18 01:13 PM
01/13/18 01:13 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
What grade does the engine spec, 5' or 10w30? Any mechanic that suggests running an oil that much thicker in a stock engine in an attempt at anything other than a short-term, stop-gap fix (even then it's a stretch) has some serious catching up to do.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Mechanics advice on 5.9 Dodge Magnum [Re: Alex_V] #4633594
01/13/18 01:20 PM
01/13/18 01:20 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Originally Posted By: mbacfp
2003 Dodge Durango 5.9...94,500 miles. Concerned about oil consumption. 1.5 quarts every 3,000 miles or so. Using Pennzoil Platinum 10w-30, yearly OCI. Should I try a high mileage 10w-30 or go straight to a 5w-40. No smoke, leaks, etc. Interested in combating oil consumption. Any advice on this motor.
^ From another thread. Sometimes with that oil it takes a few intervals for the consumption to level off. Same thing with Pennzoil Ultra. Just keep using it and see if the consumption gets better. And below from 1/8/18:
Not convinced it is Plenum...probably going to fix with Hughes Kit anyway. Curious what High Mileage oils were good to start using going forward. Thanks and I promise no more threads on this issue.
Thanks BrocLuno. I apologize to all for so many similar threads. Will not happen again.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633616
01/13/18 01:47 PM
01/13/18 01:47 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Thanks to all. Been hard to diagnose without removing parts. Looked down throttle body and their is some dark discoloration, but no puddles of oil. I have no other symptoms of Plenum other than oil consumption. Car sat for a week and absolutely no smoke at start up or rough ideling, etc. Changed PCV with OEM. I apologize if I have annoyed anyone with my circular oil consumption posts. I have decided to do Plenum and hope that is it. Thanks for putting up with posts.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633698
01/13/18 03:14 PM
01/13/18 03:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No problem...
We are just trying to keep you from "Loading up the parts shotgun" and blasting away (hoping any number of them fixes the problem.
I would diagnose it first before ordering anything.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633745
01/13/18 04:01 PM
01/13/18 04:01 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
I appreciate it. I am going to have it looked into for sure before throwing uneeded money into it. Probably a little over my head in taking throttle body and intake manifold out to diagnose. I will update everyone on what I find. Appreciate everyone's help and patience.
Re: Mechanics advice on 5.9 Dodge Magnum [Re: mbacfp] #4633748
01/13/18 04:03 PM
01/13/18 04:03 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
You need a new mechanic.
The "thinking" man's friend.
