Originally Posted By: zeng
Originally Posted By: StevieC
Quote:
Lower viscosity engine oils can provide better fuel
economy and cold weather performance, however, higher viscosity
engine oils are required for satisfactory lubrication in hot weather.
I think this assumes conventional oil in use with the bare minimum MOFT that might be encountered not high quality synthetics.
I'm afraid this assumption is not valid.
Do elaborate and consider that the vehicles are sold around the world where oil quality my not be as good as it is in certain countries.
MOFT is a property of
* bearing dimensions (diameter, length and clearance)
* applied pressure (load/projected area)
* RPM
* viscosity
If you change the viscosity, it doesn't matter whether it is conventional, synthetic, or vegetable oil vis/vis at the same temperature, MOFT doesn't change.
When you run out of MOFT, and asperite contact ensues, additives come into play as the wear reduction strategy.
The only "zero" wear option is full hydrodynamic.
